Giriş
If the touchscreen on your HP Pavilion x360 14m-ba011dx laptop isn’t responding to touch, is cracked, or looks burned out, this guide will walk you through how to replace it.
Make sure to exercise caution when removing the touchscreen, as it is made of glass and will crack if it is bent.
Neye ihtiyacın var
Remove the top left and right rubber pads closest to the hinge of screen using a plastic spudger to expose the screws underneath.
Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:
Two 7.5 mm screws.
Three 5 mm screws.
One 6.5 mm screw.
Insert the Jimmy between the screen and back case.
Carefully detach the screen from the back case by sliding the Jimmy around the casing and prying the screen from the case.
