Ana içeriğe geç
HP Pavilion x360 14m-ba011dx Speakers Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 14m-ba011dx Speakers Replacement, Speakers: adım 1, 2 resimden 1. HP Pavilion x360 14m-ba011dx Speakers Replacement, Speakers: adım 1, 2 resimden 2.
    • Remove the top left and right rubber pads closest to the hinge of screen using a plastic spudger to locate the screws underneath.
    • Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:​
    • Remove two 7.5 mm screws.
    • Remove three 5 mm screws.
    • Remove one 6.5 mm screw.
  2. HP Pavilion x360 14m-ba011dx Speakers Replacement: adım 2, 1 resimden 1.
    • Push into the two screw holes that were under the rubber pads with the screwdriver to pop the keyboard out just a little.
    • Do this with the screen open so that you do not damage the screen.
    • Do not remove keyboard all the way.
  3. HP Pavilion x360 14m-ba011dx Speakers Replacement: adım 3, 2 resimden 1. HP Pavilion x360 14m-ba011dx Speakers Replacement: adım 3, 2 resimden 2.
    • Separate the keyboard from the rest of the device using a metal spudger around edges.
    • Pull up gently just until you can see the cables attaching the keyboard to the motherboard.
    • Flip the small white flaps holding the cables to the motherboard open to unplug the cords.
  4. HP Pavilion x360 14m-ba011dx Speakers Replacement: adım 4, 1 resimden 1.
    • Disconnect the wires labeled 1 and 2 out.
  5. HP Pavilion x360 14m-ba011dx Speakers Replacement: adım 5, 1 resimden 1.
    • Disconnect two ZIF connectors from the motherboard.
    • Remove three 4mm screws using a Phillips #00 Screwdriver.
  6. HP Pavilion x360 14m-ba011dx Speakers Replacement: adım 6, 1 resimden 1.
    • Gently remove the speakers from the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 220
