Ana içeriğe geç
HP Pavilion x360 14m-cd0003dx Battery Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 14m-cd0003dx Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Battery Replacement: adım 2, 2 resimden 1. HP Pavilion x360 14m-cd0003dx Battery Replacement: adım 2, 2 resimden 2.
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx Battery Replacement: adım 3, 3 resimden 1. HP Pavilion x360 14m-cd0003dx Battery Replacement: adım 3, 3 resimden 2. HP Pavilion x360 14m-cd0003dx Battery Replacement: adım 3, 3 resimden 3.
    • Remove the six 5 mm battery screws, and the battery can then be taken out.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Mason T Arruda
165 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 üyesi
UMASSD-SINCLAIRE-S22S7G4
6 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Hallo
vielen Dank für diese coole Anleitung
als Ergänzung
beim Model 14-cd0101ng gibt es lediglich die beiden unteren Schrauben (siehe schritt, zwei 6mm schrauben) nicht.
Ansonsten konnte ich keine unterschiede feststellen!
Eng:
For Model 14-cd0101ng it is the same way, without the two 6mm Phillips screws underneath!
Erwin “ReudenBub” Po - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 40
Her zaman: 1,936
