Ana içeriğe geç
HP Pavilion x360 14m-cd0003dx Fan Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 14m-cd0003dx Fan Replacement, Heat Sink and Fan: adım 1, 1 resimden 1.
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Fan Replacement: adım 2, 2 resimden 1. HP Pavilion x360 14m-cd0003dx Fan Replacement: adım 2, 2 resimden 2.
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx Fan Replacement: adım 3, 2 resimden 1. HP Pavilion x360 14m-cd0003dx Fan Replacement: adım 3, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the seven 5 mm screws that secure the fan and heatsink.
  4. HP Pavilion x360 14m-cd0003dx Fan Replacement: adım 4, 1 resimden 1.
    • Peel back the retention tape that secures the heat sink assembly.
  5. HP Pavilion x360 14m-cd0003dx Fan Replacement: adım 5, 1 resimden 1.
    • Disconnect the fan cable from the connector on the system board.
  6. HP Pavilion x360 14m-cd0003dx Fan Replacement: adım 6, 1 resimden 1.
    • Remove the heat sink assembly from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Riley McMorrow
264 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 üyesi
UMASSD-SINCLAIRE-S22S7G4
6 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 465
