Ana içeriğe geç
HP Pavilion x360 14m-cd0003dx SSD Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 14m-cd0003dx SSD Replacement, SSD: adım 1, 1 resimden 1.
    • Make sure computer is turned off
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx SSD Replacement: adım 2, 3 resimden 1. HP Pavilion x360 14m-cd0003dx SSD Replacement: adım 2, 3 resimden 2. HP Pavilion x360 14m-cd0003dx SSD Replacement: adım 2, 3 resimden 3.
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx SSD Replacement: adım 3, 2 resimden 1. HP Pavilion x360 14m-cd0003dx SSD Replacement: adım 3, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the 5 mm screw that secures the SSD.
  4. HP Pavilion x360 14m-cd0003dx SSD Replacement: adım 4, 2 resimden 1. HP Pavilion x360 14m-cd0003dx SSD Replacement: adım 4, 2 resimden 2.
    • Peel back the black covering.
    • Pull out SSD.
Sonuç
Jack Benfeito
180 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 üyesi
UMASSD-SINCLAIRE-S22S7G4
6 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 31
Her zaman: 938
