Ana içeriğe geç
HP Pavilion x360 14m-cd0003dx Touchpad Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: adım 2, 2 resimden 1. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: adım 2, 2 resimden 2.
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: adım 3, 3 resimden 1. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: adım 3, 3 resimden 2. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: adım 3, 3 resimden 3.
    • Remove the six 5 mm battery screws, and the battery can then be taken out.
  4. HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: adım 4, 3 resimden 1. HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: adım 4, 3 resimden 2. HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: adım 4, 3 resimden 3.
    • Lift the black tab on the ZIF connector, and gently pull the track pad ribbon cable free.
  5. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: adım 5, 3 resimden 1. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: adım 5, 3 resimden 2. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: adım 5, 3 resimden 3.
    • Use a Phillips Head Screwdriver to remove the bottom 3 screws (5 mm).
    • Remove the metal plate that secures the touch pad.
  6. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: adım 6, 2 resimden 1. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: adım 6, 2 resimden 2.
    • Use a Phillips Head Screwdriver to unscrew top 3 screws (5 mm).
    • Remove touch pad.
Sonuç
Elijah Jope
379 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 üyesi
UMASSD-SINCLAIRE-S22S7G4
6 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 380
