Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Turn off and shut down the computer.
Disconnect the power adapter and all external devices connected to the computer.
Flip the device with the backplate up and with the hinge on the far side.
Use the opening tool to remove the rubber feet attached to the bottom of the device.
Remove all screws located on the bottom of the device:
Two Phillips #0 7.0mm screws
Three Phillips #00 4.5mm screws
Using the opening tool, carefully remove the bottom cover from the device.
Use a #00 Phillips screwdriver to remove:
Six 2.5 mm screws
Find the fan cable
Use the Reverse Tweezers to unplug the fan cable
Remove all screws securing the fan to the device:
Two Phillips #00 4.5mm screws
Four Phillips #00 4.5mm screws
Lift and remove the fan and heat sink from the device.
2 farklı kişi bu kılavuzu tamamladı.
