Ana içeriğe geç
HP Pavilion x360 15t-br000 Battery Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 15t-br000 Battery Replacement, Keyboard Panel: adım 1, 3 resimden 1. HP Pavilion x360 15t-br000 Battery Replacement, Keyboard Panel: adım 1, 3 resimden 2. HP Pavilion x360 15t-br000 Battery Replacement, Keyboard Panel: adım 1, 3 resimden 3.
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Battery Replacement: adım 2, 3 resimden 1. HP Pavilion x360 15t-br000 Battery Replacement: adım 2, 3 resimden 2. HP Pavilion x360 15t-br000 Battery Replacement: adım 2, 3 resimden 3.
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Disconnect the battery cable from the device.
  4. HP Pavilion x360 15t-br000 Battery Replacement: adım 4, 2 resimden 1. HP Pavilion x360 15t-br000 Battery Replacement: adım 4, 2 resimden 2.
    • Remove the seven Phillips #0 4.5 mm screws.
    • Remove the battery from the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 26
Her zaman: 867
