Ana içeriğe geç
HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Keyboard Panel: adım 1, 3 resimden 1. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Keyboard Panel: adım 1, 3 resimden 2. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Keyboard Panel: adım 1, 3 resimden 3.
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: adım 2, 3 resimden 1. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: adım 2, 3 resimden 2. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: adım 2, 3 resimden 3.
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: adım 3, 3 resimden 1. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: adım 3, 3 resimden 2. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: adım 3, 3 resimden 3.
    • Remove all three 3.5 mm screws using the Phillips #0 screwdriver.
    • Disconnect the cables above the fan.
    • Disconnect the wire next to the fan.
  4. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: adım 4, 1 resimden 1.
    • Remove nine 4mm screws using the Phillips #0 screwdriver.
  5. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: adım 5, 1 resimden 1.
    • Flip over the motherboard.
  6. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: adım 6, 2 resimden 1. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: adım 6, 2 resimden 2.
    • Remove four 3.5mm screws using the Phillips #0 screwdriver.
    • Remove the fan and heatsink assembly from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 517
