Ana içeriğe geç
HP Pavilion x360 15t-br000 Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 15t-br000 Hard Drive Replacement, Keyboard Panel: adım 1, 3 resimden 1. HP Pavilion x360 15t-br000 Hard Drive Replacement, Keyboard Panel: adım 1, 3 resimden 2. HP Pavilion x360 15t-br000 Hard Drive Replacement, Keyboard Panel: adım 1, 3 resimden 3.
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Hard Drive Replacement: adım 2, 3 resimden 1. HP Pavilion x360 15t-br000 Hard Drive Replacement: adım 2, 3 resimden 2. HP Pavilion x360 15t-br000 Hard Drive Replacement: adım 2, 3 resimden 3.
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Use the Phillips #0 screwdriver to remove four screws from the hard drive.
    • Remove the hard drive from the device.
    • At the time of creating this guide, the hard drive was not present in the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 24
Her zaman: 787
