Giriş
If your HP Pavilion x360 Convertible 14-dw1025nr is not displaying graphics or is not distributing audio, the laptop's motherboard may be damaged. Use this guide to replace it.
The motherboard is the backbone of a laptop and controls multiple parts within the laptop.
Replacing the motherboard of a laptop is not a common procedure. Most replacements within a laptop are for components that are attached to the motherboard. The motherboard should only need to be replaced in extreme situations where a separate component attached to the motherboard cannot be replaced.
Replacing the motherboard is not a difficult task, but it does require a lot of steps and there will be many small pieces to keep track of. There are various screws and a few loose plastic parts that will come out when exposing the motherboard. This replacement will not require any difficult tasks such as soldering or rewiring.
Neye ihtiyacın var
Turn off the device and set it upside down. Orient the hinges away from you.
Wedge the opening pick under the grip. Lift the end of the grip.
Pull the grip off all the way. Repeat for the second grip.
Bu adımda kullanılan alet:Tweezers$3.99
Remove the sticker covering the touch sensor connector using the angled tweezers.
Firmly pinch the plastic loop and pull straight up to disconnect the touch sensor.
