Giriş
If your HP Pavilion x360 Convertible 14-dw1025nr's memory is malfunctioning, the laptop's RAM may be damaged. Use this guide to replace it.
The RAM controls functions such as loading applications, browsing the internet, and switching between these tasks.
The replacement of the RAM involves a minimal amount of steps that repeat once for the two sticks of RAM within the laptop. The only tools needed for the replacement are plastic opening tools, a Phillips #0 screwdriver, Phillips #1 screwdriver, and a spudger.
Neye ihtiyacın var
Turn off the device and set it upside down. Orient the hinges away from you.
Wedge the opening pick under the grip. Lift the end of the grip.
Pull the grip off all the way. Repeat for the second grip.
