Ana içeriğe geç
HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): adım 1, 3 resimden 1. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): adım 1, 3 resimden 2. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): adım 1, 3 resimden 3.
    • Turn off the device and set it upside down. Orient the hinges away from you.
    • Wedge the opening pick under the grip. Lift the end of the grip.
    • Pull the grip off all the way. Repeat for the second grip.
  2. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: adım 2, 3 resimden 1. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: adım 2, 3 resimden 2. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: adım 2, 3 resimden 3.
    • Use PH0 to remove the 3mm screw from the center bottom.
    • Use PH1 to remove the 6mm screw from all four corners.
  3. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: adım 3, 3 resimden 1. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: adım 3, 3 resimden 2. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: adım 3, 3 resimden 3.
    • Use the opening pick to separate the back panel from the device.
    • Begin near the hinge and carefully follow the perimeter until you have taken the pick around all four sides.
    • The back panel will come loose once the pick has been around the whole edge of the device.
    • Lift the panel off.
  4. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: adım 4, 2 resimden 1. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: adım 4, 2 resimden 2.
    • Pinch and lift the small WLAN plate.
  5. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: adım 5, 1 resimden 1.
    • Use PH1 to remove the 2.5mm holding screw.
  6. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: adım 6, 2 resimden 1. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: adım 6, 2 resimden 2.
    • Pull the SSD out and up, away from the connector.
Sonuç
Amber Norton
661 İtibar
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 473
