Ana içeriğe geç
HP Pavilion x360 m1-u001dx Battery Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 m1-u001dx Battery Replacement, Keyboard: adım 1, 1 resimden 1.
    • Power off your device and disconnect all external devices connected to the laptop.
    • Working on your device while it is powered on may cause damage to the laptop or result in electric shock.
  2. HP Pavilion x360 m1-u001dx Battery Replacement: adım 2, 1 resimden 1.
    • Flip the laptop over and remove the rubber foot with a Metal Spudger.
  3. HP Pavilion x360 m1-u001dx Battery Replacement: adım 3, 1 resimden 1.
    • Remove the screws from the bottom of the laptop with a Phillips 00 Screwdriver.
    • 5 Phillips 2.4 x 5.7 mm screws
    • 7 Phillips 2.0 x 5.0 mm screws
    • Keep the different sized screws separate for future replacement.
  4. HP Pavilion x360 m1-u001dx Battery Replacement: adım 4, 3 resimden 1. HP Pavilion x360 m1-u001dx Battery Replacement: adım 4, 3 resimden 2. HP Pavilion x360 m1-u001dx Battery Replacement: adım 4, 3 resimden 3.
    • Flip the laptop back over and open it; the keyboard should be facing upwards.
    • Using the Plastic Opening Tool, separate the keyboard from the base of the laptop.
    • The keyboard is connected to the motherboard with cable ribbons, so be very gentle and careful when lifting the keyboard.
  5. HP Pavilion x360 m1-u001dx Battery Replacement: adım 5, 3 resimden 1. HP Pavilion x360 m1-u001dx Battery Replacement: adım 5, 3 resimden 2. HP Pavilion x360 m1-u001dx Battery Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Heavy-Duty Spudger
    Satın Al
    • Raising the keyboard, disconnect the first of two cable ribbons with the Heavy-Duty Spudger.
    • Gently flip up the white plastic lock connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to disconnect the ribbon cable from the lock.
  6. HP Pavilion x360 m1-u001dx Battery Replacement: adım 6, 2 resimden 1. HP Pavilion x360 m1-u001dx Battery Replacement: adım 6, 2 resimden 2.
    • Gently flip up the white plastic lock connecting the second ribbon cable to the motherboard with the Heavy-Duty Spudger.
    • Use the blue purple tab on the ribbon cable to disconnect the ribbon cable from the lock.
  7. HP Pavilion x360 m1-u001dx Battery Replacement: adım 7, 2 resimden 1. HP Pavilion x360 m1-u001dx Battery Replacement: adım 7, 2 resimden 2.
    • After the ribbon cables are disconnected, gently lift up the keyboard to disconnect it from the base of the laptop.
  8. HP Pavilion x360 m1-u001dx Battery Replacement, Battery: adım 8, 3 resimden 1. HP Pavilion x360 m1-u001dx Battery Replacement, Battery: adım 8, 3 resimden 2. HP Pavilion x360 m1-u001dx Battery Replacement, Battery: adım 8, 3 resimden 3.
    • Remove the screws from the perimeter of the battery with a Phillips 00 Screwdriver.
    • 3 Phillips 2.0 x 4.6 mm screws
  9. HP Pavilion x360 m1-u001dx Battery Replacement: adım 9, 2 resimden 1. HP Pavilion x360 m1-u001dx Battery Replacement: adım 9, 2 resimden 2.
    • Holding the lower right corner, gently lift up the battery to disconnect it from the motherboard.
Sonuç
Katie
549 İtibar
5 adet Kılavuz yazıldı
Bir Yorum
What is the usual expected backup time for this battery?
Thanks for the instructions.
Nipu011 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 23
Her zaman: 2,316
