Ana içeriğe geç
HP Pavilion x360 m1-u001dx Fan Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 m1-u001dx Fan Replacement, Keyboard: adım 1, 1 resimden 1.
    • Power off your device and disconnect all external devices connected to the laptop.
    • Working on your device while it is powered on may cause damage to the laptop or result in electric shock.
  2. HP Pavilion x360 m1-u001dx Fan Replacement: adım 2, 1 resimden 1.
    • Flip the laptop over and remove the rubber foot with a Metal Spudger.
  3. HP Pavilion x360 m1-u001dx Fan Replacement: adım 3, 1 resimden 1.
    • Remove the screws from the bottom of the laptop with a Phillips 00 Screwdriver.
    • 5 Phillips 2.4 x 5.7 mm screws
    • 7 Phillips 2.0 x 5.0 mm screws
    • Keep the different sized screws separate for future replacement.
  4. HP Pavilion x360 m1-u001dx Fan Replacement: adım 4, 3 resimden 1. HP Pavilion x360 m1-u001dx Fan Replacement: adım 4, 3 resimden 2. HP Pavilion x360 m1-u001dx Fan Replacement: adım 4, 3 resimden 3.
    • Flip the laptop back over and open it; the keyboard should be facing upwards.
    • Using the Plastic Opening Tool, separate the keyboard from the base of the laptop.
    • The keyboard is connected to the motherboard with cable ribbons, so be very gentle and careful when lifting the keyboard.
  5. HP Pavilion x360 m1-u001dx Fan Replacement: adım 5, 3 resimden 1. HP Pavilion x360 m1-u001dx Fan Replacement: adım 5, 3 resimden 2. HP Pavilion x360 m1-u001dx Fan Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Heavy-Duty Spudger
    Satın Al
    • Raising the keyboard, disconnect the first of two cable ribbons with the Heavy-Duty Spudger.
    • Gently flip up the white plastic lock connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to disconnect the ribbon cable from the lock.
  6. HP Pavilion x360 m1-u001dx Fan Replacement: adım 6, 2 resimden 1. HP Pavilion x360 m1-u001dx Fan Replacement: adım 6, 2 resimden 2.
    • Gently flip up the white plastic lock connecting the second ribbon cable to the motherboard with the Heavy-Duty Spudger.
    • Use the blue purple tab on the ribbon cable to disconnect the ribbon cable from the lock.
  7. HP Pavilion x360 m1-u001dx Fan Replacement: adım 7, 2 resimden 1. HP Pavilion x360 m1-u001dx Fan Replacement: adım 7, 2 resimden 2.
    • After the ribbon cables are disconnected, gently lift up the keyboard to disconnect it from the base of the laptop.
  8. HP Pavilion x360 m1-u001dx Fan Replacement, Battery: adım 8, 3 resimden 1. HP Pavilion x360 m1-u001dx Fan Replacement, Battery: adım 8, 3 resimden 2. HP Pavilion x360 m1-u001dx Fan Replacement, Battery: adım 8, 3 resimden 3.
    • Remove the screws from the perimeter of the battery with a Phillips 00 Screwdriver.
    • 3 Phillips 2.0 x 4.6 mm screws
  9. HP Pavilion x360 m1-u001dx Fan Replacement: adım 9, 2 resimden 1. HP Pavilion x360 m1-u001dx Fan Replacement: adım 9, 2 resimden 2.
    • Holding the lower right corner, gently lift up the battery to disconnect it from the motherboard.
  10. HP Pavilion x360 m1-u001dx Fan Replacement, System Board (Motherboard): adım 10, 2 resimden 1. HP Pavilion x360 m1-u001dx Fan Replacement, System Board (Motherboard): adım 10, 2 resimden 2.
    • Remove the screws from the perimeter of the motherboard with a Phillips 00 Screwdriver.
    • 8 Phillips 2.0 x 4.7 mm screws.
  11. HP Pavilion x360 m1-u001dx Fan Replacement: adım 11, 3 resimden 1. HP Pavilion x360 m1-u001dx Fan Replacement: adım 11, 3 resimden 2. HP Pavilion x360 m1-u001dx Fan Replacement: adım 11, 3 resimden 3.
    • Disconnect the 3 bundle cable connectors by gently gripping the cable wires and pulling outwards.
    • Be sure to grip each of the cables equally so no single cable is overly strained.
  12. HP Pavilion x360 m1-u001dx Fan Replacement: adım 12, 3 resimden 1. HP Pavilion x360 m1-u001dx Fan Replacement: adım 12, 3 resimden 2. HP Pavilion x360 m1-u001dx Fan Replacement: adım 12, 3 resimden 3.
    Heavy-Duty Spudger
    Satın Al
    • Disconnect the 2 cable ribbons with the Heavy-Duty Spudger.
    • Use the purple plastic tab on the ribbon cable to disconnect the ribbon cable from the lock.
  13. HP Pavilion x360 m1-u001dx Fan Replacement: adım 13, 3 resimden 1. HP Pavilion x360 m1-u001dx Fan Replacement: adım 13, 3 resimden 2. HP Pavilion x360 m1-u001dx Fan Replacement: adım 13, 3 resimden 3.
    • Gently lift up the motherboard to disconnect it from the computer.
  14. HP Pavilion x360 m1-u001dx Fan Replacement, Fan: adım 14, 3 resimden 1. HP Pavilion x360 m1-u001dx Fan Replacement, Fan: adım 14, 3 resimden 2. HP Pavilion x360 m1-u001dx Fan Replacement, Fan: adım 14, 3 resimden 3.
    • Disconnect the bundle cable connector by gently gripping the cable wires and pulling outwards.
  15. HP Pavilion x360 m1-u001dx Fan Replacement: adım 15, 2 resimden 1. HP Pavilion x360 m1-u001dx Fan Replacement: adım 15, 2 resimden 2.
    • Peel off the black sticker to expose the screws underneath.
    • Do not crumple the sticker; you will need it when reassembling the fan.
  16. HP Pavilion x360 m1-u001dx Fan Replacement: adım 16, 1 resimden 1.
    • Remove the 4 screws from the motherboard with a Phillips 00 Screwdriver.
    • 4 Phillips 2.5 x 5.5 mm screws
    • Keep the screws for future replacement.
  17. HP Pavilion x360 m1-u001dx Fan Replacement: adım 17, 1 resimden 1.
    • Disconnect the fan from the motherboard by taking out the screws.
Sonuç
Katie
549 İtibar
5 adet Kılavuz yazıldı
Bir Yorum
Hello,
Where can I get the replacement fan? Or which model is it?
THANKS!!
Nir Katz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 655
