Giriş
If keys are malfunctioning (sticking or not registering), this guide will explain how to replace your keyboard. To replace your keyboard, you will need to know how to use a screwdriver. Small parts (screws) may be a swallowing hazard for young children; keep all parts in a secure location.
Neye ihtiyacın var
Power off your device and disconnect all external devices connected to the laptop.
Bu adımda kullanılan alet:Heavy-Duty Spudger$4.99
Raising the keyboard, disconnect the first of two cable ribbons with the Heavy-Duty Spudger.
Gently flip up the white plastic lock connecting the ribbon cable to the motherboard.
Use the blue plastic tab on the ribbon cable to disconnect the ribbon cable from the lock.
Bir başkası bu kılavuzu tamamladı.
