Ana içeriğe geç
HP Pavilion x360 m3-u001dx Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 m3-u001dx Hard Drive Replacement, Keyboard: adım 1, 1 resimden 1.
    • Shut down the computer.
    • Disconnect the power and all external devices connected to the computer.
    • Working on your device while it is turned on may result in electric shock.
  2. HP Pavilion x360 m3-u001dx Hard Drive Replacement: adım 2, 2 resimden 1. HP Pavilion x360 m3-u001dx Hard Drive Replacement: adım 2, 2 resimden 2.
    • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
  3. HP Pavilion x360 m3-u001dx Hard Drive Replacement: adım 3, 1 resimden 1.
    • Remove all of the screws located on the bottom of the laptop:
    • 5 Phillips 2.4 x 5.7 mm screws
    • 5 Phillips 2.0 x 5.0 mm screws
    • Make special note of each screw and screw lock size and location during removal and replacement.
  4. HP Pavilion x360 m3-u001dx Hard Drive Replacement: adım 4, 1 resimden 1.
    • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
  5. HP Pavilion x360 m3-u001dx Hard Drive Replacement: adım 5, 2 resimden 1. HP Pavilion x360 m3-u001dx Hard Drive Replacement: adım 5, 2 resimden 2.
    • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
    • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
  6. HP Pavilion x360 m3-u001dx Hard Drive Replacement: adım 6, 1 resimden 1.
    • Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
  7. HP Pavilion x360 m3-u001dx Hard Drive Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    Heavy-Duty Spudger
    Satın Al
    • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  8. HP Pavilion x360 m3-u001dx Hard Drive Replacement: adım 8, 1 resimden 1.
    • Lift the keyboard away from the base of the laptop.
  9. HP Pavilion x360 m3-u001dx Hard Drive Replacement, Battery: adım 9, 1 resimden 1.
    • Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
  10. HP Pavilion x360 m3-u001dx Hard Drive Replacement: adım 10, 1 resimden 1.
    • Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
  11. HP Pavilion x360 m3-u001dx Hard Drive Replacement, Hard Drive: adım 11, 1 resimden 1.
    Heavy-Duty Spudger
    Satın Al
    • Disconnect the ribbon cables attaching the hard drive to the system board (motherboard).
    • Use the purple plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  12. HP Pavilion x360 m3-u001dx Hard Drive Replacement: adım 12, 2 resimden 1. HP Pavilion x360 m3-u001dx Hard Drive Replacement: adım 12, 2 resimden 2.
    • Using the Phillips00 Screw Driver, remove 4 Phillips 2.0 x 4.6 mm screws around the perimeter of the hard drive.
  13. HP Pavilion x360 m3-u001dx Hard Drive Replacement: adım 13, 1 resimden 1.
    • Using the tab provided, lift and remove the hard drive out of the laptop base.
  14. HP Pavilion x360 m3-u001dx Hard Drive Replacement: adım 14, 2 resimden 1. HP Pavilion x360 m3-u001dx Hard Drive Replacement: adım 14, 2 resimden 2.
    • Using the Phillips00 Screw Driver, remove 4 Phillips 3.0 x 3.7 mm screws on exterior mounting bracket.
    • There are 2 Phillips screws on each side of the hard drive bracket.
  15. HP Pavilion x360 m3-u001dx Hard Drive Replacement: adım 15, 1 resimden 1.
    • Remove the mounting bracket.
Sonuç
Follow these instructions in reverse order to reassemble your device.
9 farklı kişi bu kılavuzu tamamladı.
Subhleen
1.268 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-6, Rose Winter 2017 UW Tacoma, Team 1-6, Rose Winter 2017 üyesi
UWT-ROSE-W17S1G6
4 Üyeler
8 adet Kılavuz yazıldı
8 Yorum
Awesome. Thanks. This helped me a lot.
Gouse Khan - Yanıt
Can anyone tell me the model number of the hdd ribbon cable please :)
James Harris - Yanıt
I need to replace the data ribbon as well.
KurwynK -
Found it. part# 856011–001
KurwynK - Yanıt
My HP Pavilion X360 M3-u00ldx is not recognizing my brand new Samsung 860 Evo 500GB ssd. Upon start up I get  3F0 error which states there is no hard drive. When I boot to a Windows 10 disc it also doesn't recognize it.
Any suggestions on how it can be recognized is appreciated.
Thank you for looking.
downdog89 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 18
Son 30 gün: 77
Her zaman: 22,422
