Ana içeriğe geç
HP Pavilion x360 m3-u103dx Battery Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 m3-u103dx Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Power off device.
    • Flip the laptop over.
    • Working on your device while its powered on may cause damage to your device.
  2. HP Pavilion x360 m3-u103dx Battery Replacement: adım 2, 1 resimden 1.
    • Remove rubber foot closest to computer hinge with a Metal Spudger.
  3. HP Pavilion x360 m3-u103dx Battery Replacement: adım 3, 1 resimden 1.
    • Remove all screws from base using a Phillips head 00 screwdriver.
    • 5 Phillip 2.4 x 5.7 mm screws.
    • 5 Phillips 2.8 x 5.0 mm screws.
  4. HP Pavilion x360 m3-u103dx Battery Replacement: adım 4, 3 resimden 1. HP Pavilion x360 m3-u103dx Battery Replacement: adım 4, 3 resimden 2. HP Pavilion x360 m3-u103dx Battery Replacement: adım 4, 3 resimden 3.
    • Open computer and pry open keyboard panel using the Metal Spudger. Apply little pressure then increase until keyboard pops away from motherboard.
    • Be careful not to pull or disconnect ribbon cables first.
  5. HP Pavilion x360 m3-u103dx Battery Replacement: adım 5, 2 resimden 1. HP Pavilion x360 m3-u103dx Battery Replacement: adım 5, 2 resimden 2.
    • Gently lift the keyboard on the mouse pad side, but do not remove.
    • The keyboard is still connected by three ribbon cables.
    • Remove three connected ribbon wires connecting keyboard to frame by gently disconnecting them from the motherboard.
  6. HP Pavilion x360 m3-u103dx Battery Replacement: adım 6, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove six screws around the battery.
    • 6 Phillips 2.0 x 4.6 mm screws.
  7. HP Pavilion x360 m3-u103dx Battery Replacement: adım 7, 2 resimden 1. HP Pavilion x360 m3-u103dx Battery Replacement: adım 7, 2 resimden 2.
    • Gently lift the battery up and away from the casing.
    • Carefully remove the battery from its connecting port.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Can i use the laptop even without a battery??
PAPISSS PH - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 40
Her zaman: 6,845
