Ana içeriğe geç
HP Pavilion x360 m3-u103dx Fan Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 m3-u103dx Fan Replacement, Fan: adım 1, 1 resimden 1.
    • Power off device.
    • Flip laptop over.
  2. HP Pavilion x360 m3-u103dx Fan Replacement: adım 2, 2 resimden 1. HP Pavilion x360 m3-u103dx Fan Replacement: adım 2, 2 resimden 2.
    • Remove the rubber foot with a Metal spudger
    • Remove 5 Phillip 2.4 x 5.7mm screws using a PH0 Phillips head screwdriver.
    • Remove 5 Phillips 2.8 x 5.0mm screws using a PH0 Phillips head screwdriver.
  3. HP Pavilion x360 m3-u103dx Fan Replacement: adım 3, 3 resimden 1. HP Pavilion x360 m3-u103dx Fan Replacement: adım 3, 3 resimden 2. HP Pavilion x360 m3-u103dx Fan Replacement: adım 3, 3 resimden 3.
    • Open computer and pry open keyboard panel using the Metal Spudger. Apply little pressure then increase until keyboard pops away from motherboard.
    • Gently lift keyboard on the mouse pad side. Remove three connected ribbon wires connecting keyboard to frame by gently disconnecting them from the motherboard.
  4. HP Pavilion x360 m3-u103dx Fan Replacement: adım 4, 1 resimden 1.
    • Remove eleven 2.0 x 4.6mm screws using the Phillips 00 Screwdriver
  5. HP Pavilion x360 m3-u103dx Fan Replacement: adım 5, 3 resimden 1. HP Pavilion x360 m3-u103dx Fan Replacement: adım 5, 3 resimden 2. HP Pavilion x360 m3-u103dx Fan Replacement: adım 5, 3 resimden 3.
    • Remove the motherboard gently from the base of the laptop.
    • Disconnect the fastened cables from the motherboard by carefully pushing the cable's plastic edges using the metal Spudger.
  6. HP Pavilion x360 m3-u103dx Fan Replacement: adım 6, 2 resimden 1. HP Pavilion x360 m3-u103dx Fan Replacement: adım 6, 2 resimden 2.
    • Using the Phillips 00 Screw Driver. remove 4 screws from the heat sink.
    • Remove any adhesive tape. Detach the fan/heat sink.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 7
Son 30 gün: 16
Her zaman: 1,327
