Ana içeriğe geç
HP Pavilion zd8000 Keyboard Replacement
Neye ihtiyacın var
  1. HP Pavilion zd8000 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the battery release latch towards you.
  2. HP Pavilion zd8000 Keyboard Replacement: adım 2, 2 resimden 1. HP Pavilion zd8000 Keyboard Replacement: adım 2, 2 resimden 2.
    • Pull up on the battery to remove it.
  3. HP Pavilion zd8000 Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
    • Remove the two 8mm Philips screws marked “K” on the bottom of the laptop.
  4. HP Pavilion zd8000 Keyboard Replacement: adım 4, 2 resimden 1. HP Pavilion zd8000 Keyboard Replacement: adım 4, 2 resimden 2.
    • Flip the laptop over and open the screen.
    • Push up on the four latches located at the top of the keyboard with the spudger to release them.
  5. HP Pavilion zd8000 Keyboard Replacement: adım 5, 2 resimden 1. HP Pavilion zd8000 Keyboard Replacement: adım 5, 2 resimden 2.
    • Lift the keyboard carefully because it is attached to the motherboard by a ribbon cable.
    • Lift the top of the keyboard towards you. Then, while keeping the keyboard at an angle, lift it towards the display.
  6. HP Pavilion zd8000 Keyboard Replacement: adım 6, 2 resimden 1. HP Pavilion zd8000 Keyboard Replacement: adım 6, 2 resimden 2.
    • Rotate the keyboard so that the bottom is visible.
    • With the keyboard lifted, locate the blue-striped tab on the underside of the black ribbon cable.
    • Pull the tab towards you to release the keyboard from the laptop.
Sonuç
Allie Menard
820 İtibar
13 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-56, Amido Spring 2011 Cal Poly, Team 24-56, Amido Spring 2011 üyesi
CPSU-AMIDO-S11S24G56
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 4,096
