Giriş
You'll need to remove the switch cover to reach the motherboard.
Neye ihtiyacın var
Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
Lift the cover from the right to remove it.
Place the laptop face-down and rotate it 180 degrees so the vents are facing you.
Remove the five 8mm Philips screws. Three are on the black base and two are near the hinges.
Rotate it so the display is on your right and the keyboard is on your left.
Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
The switch cover should easily separate from the laptop as you run the spudger through.
Bir başkası bu kılavuzu tamamladı.
