Ana içeriğe geç
HP Pavilion ze5000 Primary Fan Replacement
Neye ihtiyacın var
  1. HP Pavilion ze5000 Primary Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Push up on the arrow-shaped switch.
  2. HP Pavilion ze5000 Primary Fan Replacement: adım 2, 2 resimden 1. HP Pavilion ze5000 Primary Fan Replacement: adım 2, 2 resimden 2.
    • While still holding the switch up, remove the battery.
  3. HP Pavilion ze5000 Primary Fan Replacement, Keyboard: adım 3, 3 resimden 1. HP Pavilion ze5000 Primary Fan Replacement, Keyboard: adım 3, 3 resimden 2. HP Pavilion ze5000 Primary Fan Replacement, Keyboard: adım 3, 3 resimden 3.
    • Remove the two 5mm Phillips #0 screws from the hinges
  4. HP Pavilion ze5000 Primary Fan Replacement: adım 4, 2 resimden 1. HP Pavilion ze5000 Primary Fan Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Open the device as if you were going to use the device. Using Tweezers, pry the hinges from underneath the screen
    • Not much force is needed to pull the hinges off once the tweezers are properly positioned
  5. HP Pavilion ze5000 Primary Fan Replacement: adım 5, 2 resimden 1. HP Pavilion ze5000 Primary Fan Replacement: adım 5, 2 resimden 2.
    • Remove the wire connection by gently pulling on the fuse and connection itself.
    • Do not pull on the wires, as this can remove the wires from the connection, destroying the fuse.
  6. HP Pavilion ze5000 Primary Fan Replacement: adım 6, 3 resimden 1. HP Pavilion ze5000 Primary Fan Replacement: adım 6, 3 resimden 2. HP Pavilion ze5000 Primary Fan Replacement: adım 6, 3 resimden 3.
    • Remove the four 4.0 mm Phillips #0 connecting the keyboard to the frame
  7. HP Pavilion ze5000 Primary Fan Replacement: adım 7, 2 resimden 1. HP Pavilion ze5000 Primary Fan Replacement: adım 7, 2 resimden 2.
    • Gently lift the keyboard up from the frame so that you can see the ribbon still connected.
  8. HP Pavilion ze5000 Primary Fan Replacement: adım 8, 3 resimden 1. HP Pavilion ze5000 Primary Fan Replacement: adım 8, 3 resimden 2. HP Pavilion ze5000 Primary Fan Replacement: adım 8, 3 resimden 3.
    • Remove the ribbon by gently pulling up the ends of the white receiver it is inserted in to.
    • You may need to use tweezers for this part.
    • During reassembly, when inserting the ribbon, you will hear a quiet, clicking sound when pushing down on the ends of the receiver. Hearing this ensures the ribbon is in place.
  9. HP Pavilion ze5000 Primary Fan Replacement, Primary Fan: adım 9, 1 resimden 1.
    • Remove sixteen 5.0 mm Phillips #1 screws from the underside of the device
  10. HP Pavilion ze5000 Primary Fan Replacement: adım 10, 1 resimden 1.
    • Remove the one 5.0 mm Phillips #1 screw underneath the battery home
  11. HP Pavilion ze5000 Primary Fan Replacement: adım 11, 3 resimden 1. HP Pavilion ze5000 Primary Fan Replacement: adım 11, 3 resimden 2. HP Pavilion ze5000 Primary Fan Replacement: adım 11, 3 resimden 3.
    • Remove the additional four 5.0 mm Phillips #1 screws from the hinge of the device
  12. HP Pavilion ze5000 Primary Fan Replacement: adım 12, 2 resimden 1. HP Pavilion ze5000 Primary Fan Replacement: adım 12, 2 resimden 2.
    • Remove the two 4.0 mm Phillips #0 screws attached to the cicuit board above the keyboard
  13. HP Pavilion ze5000 Primary Fan Replacement: adım 13, 1 resimden 1.
    • Gently remove the disconnection to the right of the circuit board
  14. HP Pavilion ze5000 Primary Fan Replacement: adım 14, 2 resimden 1. HP Pavilion ze5000 Primary Fan Replacement: adım 14, 2 resimden 2.
    • Take the circuit board off by pulling up on the right side of the circuit board
    • The board is plugged in to the device at this location still, but the outlet is hidden.
    • Pulling on the right side can snap the circuit board, so it is essential you pull on this side only
  15. HP Pavilion ze5000 Primary Fan Replacement: adım 15, 2 resimden 1. HP Pavilion ze5000 Primary Fan Replacement: adım 15, 2 resimden 2.
    • Remove the five 5.0 mm Phillips #1 screws from underneath the keyboard
  16. HP Pavilion ze5000 Primary Fan Replacement: adım 16, 3 resimden 1. HP Pavilion ze5000 Primary Fan Replacement: adım 16, 3 resimden 2. HP Pavilion ze5000 Primary Fan Replacement: adım 16, 3 resimden 3.
    • Disconnect the ribbons from the circuit board underneath the keyboard housing unit
  17. HP Pavilion ze5000 Primary Fan Replacement: adım 17, 3 resimden 1. HP Pavilion ze5000 Primary Fan Replacement: adım 17, 3 resimden 2. HP Pavilion ze5000 Primary Fan Replacement: adım 17, 3 resimden 3.
    • Remove the connection beneath the left hinge of the device
  18. HP Pavilion ze5000 Primary Fan Replacement: adım 18, 2 resimden 1. HP Pavilion ze5000 Primary Fan Replacement: adım 18, 2 resimden 2.
    • Pry the device apart to expose the inside of the device
    • This should be relatively easy since all connections and screws are removed. However, a spudger can be used if you are having difficulties.
  19. HP Pavilion ze5000 Primary Fan Replacement: adım 19, 3 resimden 1. HP Pavilion ze5000 Primary Fan Replacement: adım 19, 3 resimden 2. HP Pavilion ze5000 Primary Fan Replacement: adım 19, 3 resimden 3.
    • Remove the latches securing the fan housing unit by unscrewing the six 4.0 mm Phillips #0 screws
  20. HP Pavilion ze5000 Primary Fan Replacement: adım 20, 1 resimden 1.
    • Lift the housing unit a few inches from the device to expose the two small connections.
  21. HP Pavilion ze5000 Primary Fan Replacement: adım 21, 2 resimden 1. HP Pavilion ze5000 Primary Fan Replacement: adım 21, 2 resimden 2.
    • Remove the two small connections directly above and below the fan housing unit
  22. HP Pavilion ze5000 Primary Fan Replacement: adım 22, 2 resimden 1. HP Pavilion ze5000 Primary Fan Replacement: adım 22, 2 resimden 2.
    • Remove the fan housing unit and flip it over
  23. HP Pavilion ze5000 Primary Fan Replacement: adım 23, 3 resimden 1. HP Pavilion ze5000 Primary Fan Replacement: adım 23, 3 resimden 2. HP Pavilion ze5000 Primary Fan Replacement: adım 23, 3 resimden 3.
    • Remove the eight 3.5 mm Phillips #00 screws from the fan housing unit
  24. HP Pavilion ze5000 Primary Fan Replacement: adım 24, 2 resimden 1. HP Pavilion ze5000 Primary Fan Replacement: adım 24, 2 resimden 2.
    • Remove both or whichever fan needs to be replaced
    • There should be bronze electric tape on the fan housing unit. Do not hesitate to tear the tape in order to open the housing unit
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Eric Beaudry
823 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G7, Bernier Spring 2018 UMass Dartmouth, Team S2-G7, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S2G7
2 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 211
