Ana içeriğe geç
HP Pavilion ze5000 Screen Replacement
Neye ihtiyacın var
    1. HP Pavilion ze5000 Screen Replacement, Screen: adım 1, 3 resimden 1. HP Pavilion ze5000 Screen Replacement, Screen: adım 1, 3 resimden 2. HP Pavilion ze5000 Screen Replacement, Screen: adım 1, 3 resimden 3.
      • Remove two 5.0 mm Philips #0 screws on the hinge of the device
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion ze5000 Screen Replacement: adım 2, 2 resimden 1. HP Pavilion ze5000 Screen Replacement: adım 2, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Using tweezers, gently pull on the hinges to remove the plastic case connected to the hinges
      FixBot'a Sor
      Yorum Ekle
    3. HP Pavilion ze5000 Screen Replacement: adım 3, 3 resimden 1. HP Pavilion ze5000 Screen Replacement: adım 3, 3 resimden 2. HP Pavilion ze5000 Screen Replacement: adım 3, 3 resimden 3.
      • Remove the connection between the plastic case and interior of the device
      FixBot'a Sor
      Yorum Ekle
    4. HP Pavilion ze5000 Screen Replacement: adım 4, 3 resimden 1. HP Pavilion ze5000 Screen Replacement: adım 4, 3 resimden 2. HP Pavilion ze5000 Screen Replacement: adım 4, 3 resimden 3.
      • Remove the connection from the exposed hinge and interior of the device
      FixBot'a Sor
      Yorum Ekle
    5. HP Pavilion ze5000 Screen Replacement: adım 5, 2 resimden 1. HP Pavilion ze5000 Screen Replacement: adım 5, 2 resimden 2.
      • Remove the 3.5 mm philips #00 screw on the small circuit board on the hinge
      FixBot'a Sor
      Yorum Ekle
    6. HP Pavilion ze5000 Screen Replacement: adım 6, 2 resimden 1. HP Pavilion ze5000 Screen Replacement: adım 6, 2 resimden 2.
      • Remove the 5.0 mm philips #0 screw that was hidden underneath the small circuit board
      FixBot'a Sor
      Yorum Ekle
    7. HP Pavilion ze5000 Screen Replacement: adım 7, 1 resimden 1.
      • Remove the 6 plastic caps located in the four corners of the screen and the top of the screen
      • It may be easier to use tweezers for this part
      FixBot'a Sor
      Yorum Ekle
    8. HP Pavilion ze5000 Screen Replacement: adım 8, 3 resimden 1. HP Pavilion ze5000 Screen Replacement: adım 8, 3 resimden 2. HP Pavilion ze5000 Screen Replacement: adım 8, 3 resimden 3.
      • Unscrew the six 5.0 mm Philips #0 screws underneath the caps
      FixBot'a Sor
      Yorum Ekle
    9. HP Pavilion ze5000 Screen Replacement: adım 9, 3 resimden 1. HP Pavilion ze5000 Screen Replacement: adım 9, 3 resimden 2. HP Pavilion ze5000 Screen Replacement: adım 9, 3 resimden 3.
      • Using a spudger, pry the plastic casing off of the screen.
      FixBot'a Sor
      Yorum Ekle
    10. HP Pavilion ze5000 Screen Replacement: adım 10, 3 resimden 1. HP Pavilion ze5000 Screen Replacement: adım 10, 3 resimden 2. HP Pavilion ze5000 Screen Replacement: adım 10, 3 resimden 3.
      • Remove four 5.0 mm Philips #0 screws located in the corners of the screen
      • These screws locations will be close to the screws locations in step 2.
      • During reassembly, make sure you do not confuse the proper screw placements from this step and step 4.
      FixBot'a Sor
      Yorum Ekle
    11. HP Pavilion ze5000 Screen Replacement: adım 11, 2 resimden 1. HP Pavilion ze5000 Screen Replacement: adım 11, 2 resimden 2.
      • Remove the four 3.5 mm Philips #00 screws from the sides of the aluminum casing.
      • There will be two 3.5 mm Philips screws on each side
      FixBot'a Sor
      Yorum Ekle
Sonuç
Eric Beaudry
823 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G7, Bernier Spring 2018 UMass Dartmouth, Team S2-G7, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S2G7
2 Üyeler
28 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 29
Her zaman: 475
