Ana içeriğe geç
HP Pavilion ze5000 Screen Replacement
Neye ihtiyacın var
  1. HP Pavilion ze5000 Screen Replacement, Screen: adım 1, 3 resimden 1. HP Pavilion ze5000 Screen Replacement, Screen: adım 1, 3 resimden 2. HP Pavilion ze5000 Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Remove two 5.0 mm Philips #0 screws on the hinge of the device
  2. HP Pavilion ze5000 Screen Replacement: adım 2, 2 resimden 1. HP Pavilion ze5000 Screen Replacement: adım 2, 2 resimden 2.
    • Using tweezers, gently pull on the hinges to remove the plastic case connected to the hinges
  3. HP Pavilion ze5000 Screen Replacement: adım 3, 3 resimden 1. HP Pavilion ze5000 Screen Replacement: adım 3, 3 resimden 2. HP Pavilion ze5000 Screen Replacement: adım 3, 3 resimden 3.
    • Remove the connection between the plastic case and interior of the device
  4. HP Pavilion ze5000 Screen Replacement: adım 4, 3 resimden 1. HP Pavilion ze5000 Screen Replacement: adım 4, 3 resimden 2. HP Pavilion ze5000 Screen Replacement: adım 4, 3 resimden 3.
    • Remove the connection from the exposed hinge and interior of the device
  5. HP Pavilion ze5000 Screen Replacement: adım 5, 2 resimden 1. HP Pavilion ze5000 Screen Replacement: adım 5, 2 resimden 2.
    • Remove the 3.5 mm philips #00 screw on the small circuit board on the hinge
  6. HP Pavilion ze5000 Screen Replacement: adım 6, 2 resimden 1. HP Pavilion ze5000 Screen Replacement: adım 6, 2 resimden 2.
    • Remove the 5.0 mm philips #0 screw that was hidden underneath the small circuit board
  7. HP Pavilion ze5000 Screen Replacement: adım 7, 1 resimden 1.
    • Remove the 6 plastic caps located in the four corners of the screen and the top of the screen
    • It may be easier to use tweezers for this part
  8. HP Pavilion ze5000 Screen Replacement: adım 8, 3 resimden 1. HP Pavilion ze5000 Screen Replacement: adım 8, 3 resimden 2. HP Pavilion ze5000 Screen Replacement: adım 8, 3 resimden 3.
    • Unscrew the six 5.0 mm Philips #0 screws underneath the caps
  9. HP Pavilion ze5000 Screen Replacement: adım 9, 3 resimden 1. HP Pavilion ze5000 Screen Replacement: adım 9, 3 resimden 2. HP Pavilion ze5000 Screen Replacement: adım 9, 3 resimden 3.
    • Using a spudger, pry the plastic casing off of the screen.
  10. HP Pavilion ze5000 Screen Replacement: adım 10, 3 resimden 1. HP Pavilion ze5000 Screen Replacement: adım 10, 3 resimden 2. HP Pavilion ze5000 Screen Replacement: adım 10, 3 resimden 3.
    • Remove four 5.0 mm Philips #0 screws located in the corners of the screen
    • These screws locations will be close to the screws locations in step 2.
    • During reassembly, make sure you do not confuse the proper screw placements from this step and step 4.
  11. HP Pavilion ze5000 Screen Replacement: adım 11, 2 resimden 1. HP Pavilion ze5000 Screen Replacement: adım 11, 2 resimden 2.
    • Remove the four 3.5 mm Philips #00 screws from the sides of the aluminum casing.
    • There will be two 3.5 mm Philips screws on each side
Sonuç
Eric Beaudry
823 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G7, Bernier Spring 2018 UMass Dartmouth, Team S2-G7, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S2G7
2 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 124
