Ana içeriğe geç
HP Pavilion zv5000 Hard Drive Replacement
Neye ihtiyacın var
    1. HP Pavilion zv5000 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
      • Make sure that your device is properly shut down and unplugged from any outlet.
      • Flip Pavilion over so that the bottom faces up and locate the battery in the bottom left corner.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion zv5000 Hard Drive Replacement: adım 2, 2 resimden 1. HP Pavilion zv5000 Hard Drive Replacement: adım 2, 2 resimden 2.
      • Press and slide up the battery release tab with your thumb until the battery pops out of place.
      FixBot'a Sor
      Yorum Ekle
    3. HP Pavilion zv5000 Hard Drive Replacement: adım 3, 2 resimden 1. HP Pavilion zv5000 Hard Drive Replacement: adım 3, 2 resimden 2.
      • Using two fingers, pry the rest of the battery out of the socket.
      FixBot'a Sor
      Yorum Ekle
    1. HP Pavilion zv5000 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 1. HP Pavilion zv5000 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 2.
      • Make sure that the Pavilion is completely powered down and unplugged. Failure to do so may result in an electrical shock.
      • Using the Phillips #0 screwdriver, unscrew the two Phillips PM 2.5X6.0mm screws.
      • The two screws do not come out of the hard drive assembly, they simply disconnect the assembly from the laptop.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion zv5000 Hard Drive Replacement: adım 5, 2 resimden 1. HP Pavilion zv5000 Hard Drive Replacement: adım 5, 2 resimden 2.
      • Place the spudger underneath the cover of the hard drive and push up gently until the hard drive pops out of place.
      • Completely remove the hard drive from its socket.
      • If the plastic spudger is not sturdy enough to pop the hard drive out of place, try carefully using the metal spudger.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Eliza Marks
676 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-6, Catania Fall 2016 UMass Dartmouth, Team 4-6, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S4G6
3 Üyeler
45 adet Kılavuz yazıldı
1Rehber Yorum
My hp pavilion zx5000 has a blue screen and i am unable to do anything. O. S. Is Windows.
Please help
Danny Morris - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 3,601
