Ana içeriğe geç
HP Pavillion 15-ay041wm Speakers Replacement
Neye ihtiyacın var
  1. HP Pavillion 15-ay041wm Speakers Replacement, Battery: adım 1, 2 resimden 1. HP Pavillion 15-ay041wm Speakers Replacement, Battery: adım 1, 2 resimden 2.
    • Place the laptop upside down.
  2. HP Pavillion 15-ay041wm Speakers Replacement: adım 2, 2 resimden 1. HP Pavillion 15-ay041wm Speakers Replacement: adım 2, 2 resimden 2.
    • Find the battery lock latch on the top left corner.
    • Slide the latch to the right position.
  3. HP Pavillion 15-ay041wm Speakers Replacement: adım 3, 3 resimden 1. HP Pavillion 15-ay041wm Speakers Replacement: adım 3, 3 resimden 2. HP Pavillion 15-ay041wm Speakers Replacement: adım 3, 3 resimden 3.
    • Find the battery release latch on the top right corner.
    • Slide and hold the latch towards the left to cover the battery icon.
    • Carefully slide the battery outwards.
  4. HP Pavillion 15-ay041wm Speakers Replacement, Disc Drive: adım 4, 1 resimden 1.
    • Turn the laptop upside down with the base of the laptop facing you.
    • Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
    • Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
  5. HP Pavillion 15-ay041wm Speakers Replacement: adım 5, 3 resimden 1. HP Pavillion 15-ay041wm Speakers Replacement: adım 5, 3 resimden 2. HP Pavillion 15-ay041wm Speakers Replacement: adım 5, 3 resimden 3.
    • Press the eject button.
    • Hold and carefully slide the disc drive out of the laptop.
  6. HP Pavillion 15-ay041wm Speakers Replacement, Keyboard: adım 6, 3 resimden 1. HP Pavillion 15-ay041wm Speakers Replacement, Keyboard: adım 6, 3 resimden 2. HP Pavillion 15-ay041wm Speakers Replacement, Keyboard: adım 6, 3 resimden 3.
    • Using the Jimmy, create a separation between the keyboard and bottom panel.
    • Slide around the body of the panel until the separation is big enough for you to use your fingers.
    • Separate the keyboard and bottom panel.
  7. HP Pavillion 15-ay041wm Speakers Replacement, Speakers: adım 7, 3 resimden 1. HP Pavillion 15-ay041wm Speakers Replacement, Speakers: adım 7, 3 resimden 2. HP Pavillion 15-ay041wm Speakers Replacement, Speakers: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using tweezers, disconnect the left speakers from the motherboard.
    • Remove the left and right speakers from the laptop.
  8. HP Pavillion 15-ay041wm Speakers Replacement: adım 8, 2 resimden 1. HP Pavillion 15-ay041wm Speakers Replacement: adım 8, 2 resimden 2.
    • Slide the wires connecting both speakers out from the black stoppers.
    • You can now replace the speakers.
Sonuç
Olutola Yerokun Ty
135 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 33
Her zaman: 208
