Giriş
The disc drive is responsible for the computers ability to read a CD ROM. If your HP Pavilion G60-120US is no longer able to read a CD then you may have to replace the disc drive. Before moving forward with any removal of the components, refer to HP Pavillion G60-120US Troubleshooting. After troubleshooting, refer to this guide to safely and properly replace a non-working disc drive.
Neye ihtiyacın var
Using the Phillips #0 screwdriver, remove the seven 4.0mm screws on the battery compartment of the laptop.
Insert an opening tool into the top right side of the corner, and gently lift the rest of the cover to separate if from the laptop.
Using the Phillips #0 screwdriver, remove the four 4mm screws from the midframe.
Detach the disc drive from the motherboard by gently pushing it to the right.
Remove the disc drive from the laptop.
