Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
HP Pavillion G7-2235DX Keyboard Replacement
Neye ihtiyacın var
  1. HP Pavillion G7-2235DX Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Before beginning, make sure the computer is turned off and the charger is disconnected.
    • Flip the computer over, so that the bottom is facing up.
  2. HP Pavillion G7-2235DX Keyboard Replacement: adım 2, 1 resimden 1.
    • To remove the battery, slide the battery switch to the left.
  3. HP Pavillion G7-2235DX Keyboard Replacement: adım 3, 2 resimden 1. HP Pavillion G7-2235DX Keyboard Replacement: adım 3, 2 resimden 2.
    • Using a PH Screwdriver, remove the three 7.25mm screws located on the bottom panel.
    • After removing all screws, remove the panel by sliding down.
  4. HP Pavillion G7-2235DX Keyboard Replacement: adım 4, 1 resimden 1.
    • Using a PH screwdriver, remove the screw adjacent to the white labels.
    • There is a keyboard icon next to the screw
  5. HP Pavillion G7-2235DX Keyboard Replacement: adım 5, 1 resimden 1.
    • Flip the laptop over, and open it.
  6. HP Pavillion G7-2235DX Keyboard Replacement: adım 6, 1 resimden 1.
    • Using a plastic spudger, pry beneath the keyboard near the "delete" key, and pop the keyboard up from the laptop.
    • From the open gap, continue to pry around the perimeter of the keyboard, separating it from the laptop.
  7. HP Pavillion G7-2235DX Keyboard Replacement: adım 7, 2 resimden 1. HP Pavillion G7-2235DX Keyboard Replacement: adım 7, 2 resimden 2.
    • Using both hands, carefully lift the keyboard off of the laptop.
    • There may be a ribbon attached. If so, gently pull the ribbon cable up and away from the connector.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Bre'Anna Sanders
113 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-7, Leahy Fall 2016 USF Tampa, Team 1-7, Leahy Fall 2016 üyesi
USFT-LEAHY-F16S1G7
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 20
Son 30 gün: 89
Her zaman: 2,491
