Ana içeriğe geç
HP Pavillion dm1-3010nr Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavillion dm1-3010nr Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the device over, so that the bottom cover is exposed.
    • Slide the black locking mechanism into its unlock position.
  2. HP Pavillion dm1-3010nr Hard Drive Replacement: adım 2, 1 resimden 1.
    • After unlocking the mechanism, slide the battery out of its compartment.
  3. HP Pavillion dm1-3010nr Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • With the battery removed, the back cover can be taken off with your hand.
  4. HP Pavillion dm1-3010nr Hard Drive Replacement: adım 4, 1 resimden 1.
    • Use your Phillips 0 screwdriver to remove the four 2.5mm Phillips screws which hold the hard drive in place. You can see the 4 screws in the picture circled in red.
  5. HP Pavillion dm1-3010nr Hard Drive Replacement: adım 5, 1 resimden 1.
    • To disconnect the hard drive from the motherboard, pull the black tab as seen in the picture.
  6. HP Pavillion dm1-3010nr Hard Drive Replacement: adım 6, 2 resimden 1. HP Pavillion dm1-3010nr Hard Drive Replacement: adım 6, 2 resimden 2.
    • After removing the enclosure from the device, use your Phillips 0 screwdriver to remove four 3mm Phillips screws. There are two screws on each side of the hard drive enclosure.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Amitpal Gill
375 İtibar
3 adet Kılavuz yazıldı
Ekip
UC Davis, Team S7-G1, Lore Fall 2018 UC Davis, Team S7-G1, Lore Fall 2018 üyesi
UCD-LORE-F18S7G1
3 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
Schritt 5 ist leider komplett falsch. Der SATA-Stecker muss von der Festplatte/SSD gezogen werden. Nicht irgendein Kabel vom Motherboard. Den Stecker zieht man einfacher von der HDD/SSD weg, wenn man zuerst Schritt #6 ausführt, dann ist die Metall-Lasche am Kopf des Steckers nicht mehr im Weg.
Peter C. - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 1,214
