Ana içeriğe geç
HP Pavillion dm1-3010nr Keyboard Replacement
Neye ihtiyacın var
  1. HP Pavillion dm1-3010nr Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the device over, so that the bottom cover is exposed.
    • Slide the black locking mechanism into its unlock position.
  2. HP Pavillion dm1-3010nr Keyboard Replacement: adım 2, 1 resimden 1.
    • After unlocking the mechanism, slide the battery out of its compartment.
  3. HP Pavillion dm1-3010nr Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
    • Remove the black bottom cover by using your fingernails or a thin flat tool.
  4. HP Pavillion dm1-3010nr Keyboard Replacement: adım 4, 2 resimden 1. HP Pavillion dm1-3010nr Keyboard Replacement: adım 4, 2 resimden 2.
    • Use the Phillips #0 screwdriver to remove three 5mm screws securing the keyboard.
    • The screws to be removed are circled in red in the picture provided.
    • Make sure to place the screws somewhere safe like on top of a magnet.
  5. HP Pavillion dm1-3010nr Keyboard Replacement: adım 5, 1 resimden 1.
    • Flip the laptop so that they keyboard is facing you.
    • Use a thin and flat metal to carefully lift up the top side of the keyboard and separate it from the top cover.
  6. HP Pavillion dm1-3010nr Keyboard Replacement: adım 6, 2 resimden 1. HP Pavillion dm1-3010nr Keyboard Replacement: adım 6, 2 resimden 2.
    • Now you will see the keyboard cable connector attached to a locking tab.
    • Lift up the locking tab with a thin and flat screwdriver or your fingernail.
    • The locking tab will open up at a 90 degree angle.
    • Pull the keyboard cable from the connector.
Sonuç
Rosalia Olga Dupont Ayala
210 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S7-G1, Lore Fall 2018 UC Davis, Team S7-G1, Lore Fall 2018 üyesi
UCD-LORE-F18S7G1
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 636
