Ana içeriğe geç
HP Pavillion dm4t-2100 Hard Drive
Neye ihtiyacın var
  1. HP Pavillion dm4t-2100 Hard Drive, Battery: adım 1, 2 resimden 1. HP Pavillion dm4t-2100 Hard Drive, Battery: adım 1, 2 resimden 2.
    • Shut down the computer.
    • Shutting down the computer by holding power button can cause damage to computer.
    • Turn computer upside down so the base is facing upward.
  2. HP Pavillion dm4t-2100 Hard Drive: adım 2, 3 resimden 1. HP Pavillion dm4t-2100 Hard Drive: adım 2, 3 resimden 2. HP Pavillion dm4t-2100 Hard Drive: adım 2, 3 resimden 3.
    • Slide latch next to battery icon until battery pops up.
    • Pull the battery away from the computer until completely detached.
  3. HP Pavillion dm4t-2100 Hard Drive, Hard Drive: adım 3, 3 resimden 1. HP Pavillion dm4t-2100 Hard Drive, Hard Drive: adım 3, 3 resimden 2. HP Pavillion dm4t-2100 Hard Drive, Hard Drive: adım 3, 3 resimden 3.
    • Position the computer so the front is towards you.
    • Remove two 5mm Phillips #1 screws
    • Slide the hard drive cover towards the empty battery spot and remove it.
  4. HP Pavillion dm4t-2100 Hard Drive: adım 4, 3 resimden 1. HP Pavillion dm4t-2100 Hard Drive: adım 4, 3 resimden 2. HP Pavillion dm4t-2100 Hard Drive: adım 4, 3 resimden 3.
    • Loosen two 5mm Phillips #1 screws securing plastic cover, until cover is detachable.
    • Slide cover toward empty battery area and remove it.
  5. HP Pavillion dm4t-2100 Hard Drive: adım 5, 1 resimden 1.
    • Disconnect the hard drive cable that is plugged in.
    • Lift the tab on the hard drive to pull it out of the computer.
    • Hard Drive is removed.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 492
