Ana içeriğe geç
HP Pavillion dm4t-2100 Memory Card Replacement
Neye ihtiyacın var
  1. HP Pavillion dm4t-2100 Memory Card Replacement, Battery: adım 1, 2 resimden 1. HP Pavillion dm4t-2100 Memory Card Replacement, Battery: adım 1, 2 resimden 2.
    • Shut down the computer.
    • Shutting down the computer by holding power button can cause damage to computer.
    • Turn computer upside down so the base is facing upward.
  2. HP Pavillion dm4t-2100 Memory Card Replacement: adım 2, 3 resimden 1. HP Pavillion dm4t-2100 Memory Card Replacement: adım 2, 3 resimden 2. HP Pavillion dm4t-2100 Memory Card Replacement: adım 2, 3 resimden 3.
    • Slide latch next to battery icon until battery pops up.
    • Pull the battery away from the computer until completely detached.
  3. HP Pavillion dm4t-2100 Memory Card Replacement, Memory Card: adım 3, 2 resimden 1. HP Pavillion dm4t-2100 Memory Card Replacement, Memory Card: adım 3, 2 resimden 2.
    • Loosen two 5mm Phillips #1 screws securing plastic cover, until cover is detachable.
    • Slide cover toward empty battery area and remove it.
  4. HP Pavillion dm4t-2100 Memory Card Replacement: adım 4, 2 resimden 1. HP Pavillion dm4t-2100 Memory Card Replacement: adım 4, 2 resimden 2.
    • Lift black cover overlaying memory chip.
    • Spread the tabs on each side of the memory slot to release the module.
    • Remove memory by pulling the memory out at an angle, until completely detached.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 269
