Giriş
The purpose of this guide is to teach reader to install a new LCD screen. If the current LCD screen is broken or cracked, this guide will help the reader to replace it with a new one.
Neye ihtiyacın var
Use a Phillips #00 screwdriver to remove the two 4.7 mm screws in the bottom of the plastic casing.
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Thank for this very good job, I own this this camera so it is will be quite easy to fix it following your guide.
