Ana içeriğe geç
HP Photosmart C4435 Ink Cartridge Replacement
  1. HP Photosmart C4435 Ink Cartridge Replacement, Ink Cartridge: adım 1, 2 resimden 1. HP Photosmart C4435 Ink Cartridge Replacement, Ink Cartridge: adım 1, 2 resimden 2.
    • Begin by making sure the printer is connected to a power source and is turned on.
    • The printer is turned on when the power button and screen light up.
    • This allows the cartridges to move to the front of the printer for easy access.
  2. HP Photosmart C4435 Ink Cartridge Replacement: adım 2, 3 resimden 1. HP Photosmart C4435 Ink Cartridge Replacement: adım 2, 3 resimden 2. HP Photosmart C4435 Ink Cartridge Replacement: adım 2, 3 resimden 3.
    • Pull the handle at the front of the printer to access the ink cartridges compartment.
    • The cartridges will be on the right side of the printer.
  3. HP Photosmart C4435 Ink Cartridge Replacement: adım 3, 3 resimden 1. HP Photosmart C4435 Ink Cartridge Replacement: adım 3, 3 resimden 2. HP Photosmart C4435 Ink Cartridge Replacement: adım 3, 3 resimden 3.
    • Press down on the top of the ink cartridge with little force to release them.
    • The teal cartridge is for colored ink. The black cartridge is for black ink.
  4. HP Photosmart C4435 Ink Cartridge Replacement: adım 4, 3 resimden 1. HP Photosmart C4435 Ink Cartridge Replacement: adım 4, 3 resimden 2. HP Photosmart C4435 Ink Cartridge Replacement: adım 4, 3 resimden 3.
    • Remove the protective sticker on your new ink cartridge before using it.
  5. HP Photosmart C4435 Ink Cartridge Replacement: adım 5, 2 resimden 1. HP Photosmart C4435 Ink Cartridge Replacement: adım 5, 2 resimden 2.
    • Push the new ink cartridge forward into the slot.
    • You will hear and feel the ink cartridge click into place if done correctly.
    • Repeat Steps 4 and 5 for each cartridge that needs to be replaced.
  6. HP Photosmart C4435 Ink Cartridge Replacement: adım 6, 2 resimden 1. HP Photosmart C4435 Ink Cartridge Replacement: adım 6, 2 resimden 2.
    • Close the ink compartment before using the printer.
Bitiş Çizgisi
Kalvin Trac
133 İtibar
1 Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 159
