Ana içeriğe geç
HP Photosmart D110a Power Button Replacement
Neye ihtiyacın var
  1. HP Photosmart D110a Power Button Replacement, Power Button: adım 1, 1 resimden 1.
    • Open the printer's mouth by pulling the two mouth pieces down.
    • Lift the flap covering the scanner. When you are finished, the printer should appear as shown.
  2. HP Photosmart D110a Power Button Replacement: adım 2, 1 resimden 1.
    • Remove the flap for the scanner by pulling lightly on the clip that attaches it to the printer.
    • The clip may be damaged by applying too much force.
  3. HP Photosmart D110a Power Button Replacement: adım 3, 3 resimden 1. HP Photosmart D110a Power Button Replacement: adım 3, 3 resimden 2. HP Photosmart D110a Power Button Replacement: adım 3, 3 resimden 3.
    • Remove the three screws from the top of the printer using a T9 screwdriver as shown.
    • The screws are located in the far-left, far-right, and near-right corners of the printer, with respect to the front view.
  4. HP Photosmart D110a Power Button Replacement: adım 4, 1 resimden 1.
    • Reach into the mouth of the printer and press the clip behind the power button to release the power button face.
  5. HP Photosmart D110a Power Button Replacement: adım 5, 1 resimden 1.
    • A picture of the removed power button is provided to show the location of the clip that needs to be pressed.
    • After pressing the clip, pull out the face of the power button by sliding it from the right to the left side.
  6. HP Photosmart D110a Power Button Replacement: adım 6, 3 resimden 1. HP Photosmart D110a Power Button Replacement: adım 6, 3 resimden 2. HP Photosmart D110a Power Button Replacement: adım 6, 3 resimden 3.
    • The power button face has a plastic holder that attaches the power button and the wireless button to the face plate using two slots.
    • Loosen the plastic holder by pulling the slots on the face plate away from the plastic holder.
    • Remove the plastic holder from the face plate after the slots are loosened.
  7. HP Photosmart D110a Power Button Replacement: adım 7, 3 resimden 1. HP Photosmart D110a Power Button Replacement: adım 7, 3 resimden 2. HP Photosmart D110a Power Button Replacement: adım 7, 3 resimden 3.
    • The plastic holder secures the power button by two slots.
    • Using a spudger, push the holders inward to detach the button from the plastic holder.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tim Wise
173 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-38, Forte Spring 2011 Cal Poly, Team 10-38, Forte Spring 2011 üyesi
CPSU-FORTE-S11S10G38
5 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 3,600
