Ana içeriğe geç
HP Photosmart Premium C309g Scanner Replacement
Neye ihtiyacın var
  1. HP Photosmart Premium C309g Scanner Replacement, Scanner: adım 1, 1 resimden 1.
    • Open the top of the printer. The printer should appear as shown.
  2. HP Photosmart Premium C309g Scanner Replacement: adım 2, 2 resimden 1. HP Photosmart Premium C309g Scanner Replacement: adım 2, 2 resimden 2.
    • Use the blue plastic opening tool to pry the trim pieces all the way around the printer.
    • Loosen the pieces around the edges before pulling to remove from the printer.
    • Pull the (4) trim pieces off and set them aside.
  3. HP Photosmart Premium C309g Scanner Replacement: adım 3, 2 resimden 1. HP Photosmart Premium C309g Scanner Replacement: adım 3, 2 resimden 2.
    • Using the blue plastic opening tool, pull from the middle and then slide back to remove the side panels.
    • The side trim pieces need to be removed before the front trim pieces.
  4. HP Photosmart Premium C309g Scanner Replacement: adım 4, 1 resimden 1.
    • Using the T9 Torx Security screwdriver bit, unscrew the five 12mm screws shown.
  5. HP Photosmart Premium C309g Scanner Replacement: adım 5, 1 resimden 1.
    • The scanner flap is attached by a clip that can be dislodged by pulling it gently away from the printer.
    • Keeping the scanner flap upright, slide it toward the unattached clip in order to dislodge the second clip.
    • Both clips will come unattached and you can set the scanner flap aside.
  6. HP Photosmart Premium C309g Scanner Replacement: adım 6, 1 resimden 1.
    • Lift the scanner glass piece from the printer and set it aside.
  7. HP Photosmart Premium C309g Scanner Replacement: adım 7, 2 resimden 1. HP Photosmart Premium C309g Scanner Replacement: adım 7, 2 resimden 2.
    • Gently pick up the scanner piece as shown to see the bottom side and wiring.
  8. HP Photosmart Premium C309g Scanner Replacement: adım 8, 2 resimden 1. HP Photosmart Premium C309g Scanner Replacement: adım 8, 2 resimden 2.
    • Gently remove the 2 wire ribbons shown by pulling them away from the scanner piece.
Sonuç
Charles
371 İtibar
2 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-2, Lauer Fall 2014 Michigan Tech, Team 1-2, Lauer Fall 2014 üyesi
MTU-LAUER-F14S1G2
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 1,312
