Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Neye ihtiyacın var
Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
Remove the two T10 12mm Torx screws from the left side panel.
Set aside the top panel of the printer.
Remove the two T10 12 mm Torx screws from the top front of the printer
Set aside the ink cartridge carriage.
Remove the three T10 12mm Torx screws holding the paper guide to the printer body.
Lift the paper guide directly up to remove it and set it aside.
Set aside the feed roller assembly.
Push down on the tab that is on the power and USB back panel and then away from the printer to remove the power and USB back panel.
7 farklı kişi bu kılavuzu tamamladı.
4 Yorum
Muito boas elucidações das etapas para desmontagem da HP C3180
Excellent guide! You saved my printer. Thanks!
Hi, love your instructional slide shows. Very detailed. Thank you.
So now the big question: where do I buy the parts from? I have an HP C4280 all-in-one printer/scanner and I need to replace {because of your videos} either the control panel circuitry or the main control panel. But I have no idea where to get them. Can you suggest anyone?
Thank you,
Diane L.
