Ana içeriğe geç
HP Photosmart c3180 Scanner Bulb Replacement
Neye ihtiyacın var
  1. HP Photosmart c3180 Scanner Bulb Replacement, Top Panel of HP Photosmart c3180 printer: adım 1, 2 resimden 1. HP Photosmart c3180 Scanner Bulb Replacement, Top Panel of HP Photosmart c3180 printer: adım 1, 2 resimden 2.
    • Before disassembling your printer, be sure that the printer has been unplugged to avoid any risk of injury.
    • Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
    • Remove the two T10 12mm Torx screws from the left side panel.
    FixBot'a Sor
  2. HP Photosmart c3180 Scanner Bulb Replacement: adım 2, 2 resimden 1. HP Photosmart c3180 Scanner Bulb Replacement: adım 2, 2 resimden 2.
    • Firmly pull the the back of the side panel until it separates from the body of the printer.
    • Rotate the side panel upwards while pulling it towards yourself to remove the panel.
    FixBot'a Sor
  3. HP Photosmart c3180 Scanner Bulb Replacement: adım 3, 2 resimden 1. HP Photosmart c3180 Scanner Bulb Replacement: adım 3, 2 resimden 2.
    • Rotate the printer 90 degrees clockwise.
    • Grasp the paper tray and rotate it down.
    • Insert your fingers into the slot in the printer door and pull to rotate the gate down.
    FixBot'a Sor
  4. HP Photosmart c3180 Scanner Bulb Replacement: adım 4, 2 resimden 1. HP Photosmart c3180 Scanner Bulb Replacement: adım 4, 2 resimden 2.
    • Remove the two T10 12 mm Torx screws.
    • Grasp both sides of the side panel and pull it forward to remove the panel.
    FixBot'a Sor
  5. HP Photosmart c3180 Scanner Bulb Replacement: adım 5, 2 resimden 1. HP Photosmart c3180 Scanner Bulb Replacement: adım 5, 2 resimden 2.
    • Rotate the printer 90 degrees counter clockwise.
    • Lift the scanner lid to expose the scanner glass.
    FixBot'a Sor
  6. HP Photosmart c3180 Scanner Bulb Replacement: adım 6, 1 resimden 1.
    • Do not attempt to lift the top panel off the printer yet because it is still connected to the printer body by a cable.
    FixBot'a Sor
  7. HP Photosmart c3180 Scanner Bulb Replacement: adım 7, 2 resimden 1. HP Photosmart c3180 Scanner Bulb Replacement: adım 7, 2 resimden 2.
    • Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
    • Remove the front panel by grasping its front and pulling away from the printer.
    FixBot'a Sor
  8. HP Photosmart c3180 Scanner Bulb Replacement: adım 8, 2 resimden 1. HP Photosmart c3180 Scanner Bulb Replacement: adım 8, 2 resimden 2.
    • Remove the cable connecting the top panel of the printer to the power button assembly.
    FixBot'a Sor
  9. HP Photosmart c3180 Scanner Bulb Replacement: adım 9, 1 resimden 1.
    • Carefully lift the top panel of the printer away from the printer body.
    FixBot'a Sor
  10. HP Photosmart c3180 Scanner Bulb Replacement, Scanner Bulb: adım 10, 2 resimden 1. HP Photosmart c3180 Scanner Bulb Replacement, Scanner Bulb: adım 10, 2 resimden 2.
    • Set aside the top panel of the printer.
    • Lift the scanner carriage vertically, being careful not to yank of the cables connecting it to the printer.
    FixBot'a Sor
  11. HP Photosmart c3180 Scanner Bulb Replacement: adım 11, 2 resimden 1. HP Photosmart c3180 Scanner Bulb Replacement: adım 11, 2 resimden 2.
    • Flip the scanner carriage over to expose the connectors on the bottom.
    • Carefully remove the small cable from the connector.
    • Carefully remove the large cable from the connector.
    FixBot'a Sor
  12. HP Photosmart c3180 Scanner Bulb Replacement: adım 12, 2 resimden 1. HP Photosmart c3180 Scanner Bulb Replacement: adım 12, 2 resimden 2.
    • Remove the scanner carriage from the scanner tray and flip it upside down.
    • Remove the two T10 12mm Torx screws.
    • Remove the scanner carriage from the scanner bulb.
    FixBot'a Sor
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jim
1.638 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-30, Maness Fall 2011 Cal Poly, Team 20-30, Maness Fall 2011 üyesi
CPSU-MANESS-F11S20G30
4 Üyeler
25 adet Kılavuz yazıldı
1Rehber Yorum
You say no parts needed to be purchased. You have to buy a new scanner bulb if you’re replacing it.
ddaviddierlam - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 55
Her zaman: 6,663
