Aletler
Parçalar
Hiçbir parça belirtilmedi.
Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
Remove the two T10 12mm Torx screws from the left side panel.
Rotate the printer 90 degrees counter clockwise.
Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
Remove the front panel by grasping its front and pulling away from the printer.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
You say no parts needed to be purchased. You have to buy a new scanner bulb if you’re replacing it.
