Giriş
After completing the Outer Shell Disassembly guide, this process will aid in replacing the HP Photosmart c4780 motherboard with minimal technical requirements.
Neye ihtiyacın var
Unplug the device from any energy sources.
Lift the top cover of the scanner.
Use a plastic opening tool to remove the plastic frame surrounding the glass.
Bir başkası bu kılavuzu tamamladı.
