Ana içeriğe geç
HP ProBook 4320t Keyboard Replacement Guide
Neye ihtiyacın var
  1. HP ProBook 4320t Keyboard Replacement Guide, Battery Removal: adım 1, 2 resimden 1. HP ProBook 4320t Keyboard Replacement Guide, Battery Removal: adım 1, 2 resimden 2.
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
    FixBot'a Sor
    Yorum Ekle
  2. HP ProBook 4320t Keyboard Replacement Guide, Screws: adım 2, 2 resimden 1. HP ProBook 4320t Keyboard Replacement Guide, Screws: adım 2, 2 resimden 2.
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
    FixBot'a Sor
    Yorum Ekle
  3. HP ProBook 4320t Keyboard Replacement Guide, Flip: adım 3, 1 resimden 1.
    • Flip laptop over and open it.
    FixBot'a Sor
    Yorum Ekle
  4. HP ProBook 4320t Keyboard Replacement Guide, Push N Lift: adım 4, 1 resimden 1.
    • Slightly push up while lifting up on the power button panel to release the panel.
    FixBot'a Sor
    Yorum Ekle
  5. HP ProBook 4320t Keyboard Replacement Guide, Unscrewing: adım 5, 1 resimden 1.
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
    FixBot'a Sor
    Yorum Ekle
  6. HP ProBook 4320t Keyboard Replacement Guide, Careful Now: adım 6, 2 resimden 1. HP ProBook 4320t Keyboard Replacement Guide, Careful Now: adım 6, 2 resimden 2.
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  7. HP ProBook 4320t Keyboard Replacement Guide, Disconnect Wire: adım 7, 1 resimden 1.
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Joshua
134 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-5, Blackwell Fall 2014 USF Tampa, Team 9-5, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S9G5
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 30
Her zaman: 1,256
