Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
Slightly push up while lifting up on the power button panel to release the panel.
Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
Carefully (holding both sides of the keyboard), push up and lift slightly.
Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
Use the black spudger to lift the black latch holding the keyboard ribbon cable.
Use the black spudger tool to lift the white, black, and red ribbon cable connector up so that it is disconnected.
Unscrew the two (2.5 mm Phillips) screws (located on the upper most part of the computer) holding the speakers in.
Using the black spudger tool, gently pry off the right speaker.
Bir başkası bu kılavuzu tamamladı.
