Ana içeriğe geç
HP ProBook 4320t Touchpad Replacement Guide
Neye ihtiyacın var
  1. HP ProBook 4320t Touchpad Replacement Guide, Battery Removal: adım 1, 2 resimden 1. HP ProBook 4320t Touchpad Replacement Guide, Battery Removal: adım 1, 2 resimden 2.
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
    FixBot'a Sor
    Yorum Ekle
  2. HP ProBook 4320t Touchpad Replacement Guide, Screws: adım 2, 2 resimden 1. HP ProBook 4320t Touchpad Replacement Guide, Screws: adım 2, 2 resimden 2.
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
    FixBot'a Sor
    Yorum Ekle
  3. HP ProBook 4320t Touchpad Replacement Guide, Flip: adım 3, 1 resimden 1.
    • Flip laptop over and open it.
    FixBot'a Sor
    Yorum Ekle
  4. HP ProBook 4320t Touchpad Replacement Guide, Push N Lift: adım 4, 1 resimden 1.
    • Slightly push up while lifting up on the power button panel to release the panel.
    FixBot'a Sor
    Yorum Ekle
  5. HP ProBook 4320t Touchpad Replacement Guide, Unscrewing: adım 5, 1 resimden 1.
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
    FixBot'a Sor
    Yorum Ekle
  6. HP ProBook 4320t Touchpad Replacement Guide, Careful Now: adım 6, 2 resimden 1. HP ProBook 4320t Touchpad Replacement Guide, Careful Now: adım 6, 2 resimden 2.
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  7. HP ProBook 4320t Touchpad Replacement Guide, Disconnect Wire: adım 7, 1 resimden 1.
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  8. HP ProBook 4320t Touchpad Replacement Guide, Unscrew: adım 8, 1 resimden 1.
    • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
    FixBot'a Sor
    Yorum Ekle
  9. HP ProBook 4320t Touchpad Replacement Guide, Slide the Panel Off: adım 9, 1 resimden 1.
    • Carefully slide the bottom panel to the right.
    • Keyboard is connected via a wire to the back of the panel.
    FixBot'a Sor
    Yorum Ekle
  10. HP ProBook 4320t Touchpad Replacement Guide, Lift up Carefully: adım 10, 1 resimden 1.
    • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
    • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
    FixBot'a Sor
    Yorum Ekle
  11. HP ProBook 4320t Touchpad Replacement Guide, Disconnect Wire: adım 11, 1 resimden 1.
    • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
    FixBot'a Sor
    Yorum Ekle
  12. HP ProBook 4320t Touchpad Replacement Guide, Unscrewing: adım 12, 1 resimden 1.
    • Unscrew the two (2.5 mm Phillips) screws on the touch pad retention panel (Use Phillips #0 screw driver).
    FixBot'a Sor
    Yorum Ekle
  13. HP ProBook 4320t Touchpad Replacement Guide, Remove Retention Panel: adım 13, 1 resimden 1.
    • Slightly push the touch pad retention panel forward to remove from clasp and lift up.
    FixBot'a Sor
    Yorum Ekle
  14. HP ProBook 4320t Touchpad Replacement Guide, Touch Pad Screws: adım 14, 1 resimden 1.
    • Unscrew the following two (2.0 mm Phillips) screws attached to the touchpad (Use Phillips #0 screw driver).
    FixBot'a Sor
    Yorum Ekle
  15. HP ProBook 4320t Touchpad Replacement Guide, Remove Touchpad: adım 15, 1 resimden 1.
    • Slightly lift up the bottom of the touchpad and pull towards you to free the touchpad from the casing
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Joshua
134 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-5, Blackwell Fall 2014 USF Tampa, Team 9-5, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S9G5
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 31
Her zaman: 1,642
