Ana içeriğe geç
HP ProBook 4320t Wi-Fi Card Replacement Guide
Neye ihtiyacın var
  1. HP ProBook 4320t Wi-Fi Card Replacement Guide, Battery Removal: adım 1, 2 resimden 1. HP ProBook 4320t Wi-Fi Card Replacement Guide, Battery Removal: adım 1, 2 resimden 2.
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  2. HP ProBook 4320t Wi-Fi Card Replacement Guide, Screws: adım 2, 2 resimden 1. HP ProBook 4320t Wi-Fi Card Replacement Guide, Screws: adım 2, 2 resimden 2.
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  3. HP ProBook 4320t Wi-Fi Card Replacement Guide, Flip: adım 3, 1 resimden 1.
    • Flip laptop over and open it.
  4. HP ProBook 4320t Wi-Fi Card Replacement Guide, Push N Lift: adım 4, 1 resimden 1.
    • Slightly push up while lifting up on the power button panel to release the panel.
  5. HP ProBook 4320t Wi-Fi Card Replacement Guide, Unscrewing: adım 5, 1 resimden 1.
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  6. HP ProBook 4320t Wi-Fi Card Replacement Guide, Careful Now: adım 6, 2 resimden 1. HP ProBook 4320t Wi-Fi Card Replacement Guide, Careful Now: adım 6, 2 resimden 2.
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
  7. HP ProBook 4320t Wi-Fi Card Replacement Guide, Disconnect Wire: adım 7, 1 resimden 1.
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
  8. HP ProBook 4320t Wi-Fi Card Replacement Guide, Unscrew: adım 8, 1 resimden 1.
    • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
  9. HP ProBook 4320t Wi-Fi Card Replacement Guide, Slide the Panel Off: adım 9, 1 resimden 1.
    • Carefully slide the bottom panel to the right.
    • Keyboard is connected via a wire to the back of the panel.
  10. HP ProBook 4320t Wi-Fi Card Replacement Guide, Lift up Carefully: adım 10, 1 resimden 1.
    • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
    • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
  11. HP ProBook 4320t Wi-Fi Card Replacement Guide, Disconnect Wire: adım 11, 1 resimden 1.
    • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
  12. HP ProBook 4320t Wi-Fi Card Replacement Guide, Wi-Fi Card: adım 12, 1 resimden 1.
    • Use black spudger to detach the two antenna cable connectors to the Wi-Fi card.
    • Be careful not to break the cords.
  13. HP ProBook 4320t Wi-Fi Card Replacement Guide: adım 13, 1 resimden 1.
    • Unscrew the two (2.5 mm Phillips) screws holding the wifi card in.
    • Be careful because upon the last turn of the screw, the Wi-Fi card lifts up slightly.
  14. HP ProBook 4320t Wi-Fi Card Replacement Guide: adım 14, 1 resimden 1.
    • Pull the Wi-Fi card towards the left to remove.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joshua
134 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-5, Blackwell Fall 2014 USF Tampa, Team 9-5, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S9G5
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 639
