Ana içeriğe geç
HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement
Neye ihtiyacın var
  1. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Battery: adım 1, 2 resimden 1. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure the laptop is turned off before you start.
    • Push and hold the release tab on the right and left toward the center.
  2. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: adım 2, 2 resimden 1. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: adım 2, 2 resimden 2.
    • Pull the battery out.
  3. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Backplate: adım 3, 3 resimden 1. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Backplate: adım 3, 3 resimden 2. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Backplate: adım 3, 3 resimden 3.
    • Push and hold the release tabs on the right and left toward the center again.
  4. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: adım 4, 1 resimden 1.
    • Slide the backplate off.
  5. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Hard Disc Drive (HDD): adım 5, 2 resimden 1. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Hard Disc Drive (HDD): adım 5, 2 resimden 2.
    • Locate the hard drive, opposite the battery across from the wireless card.
  6. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: adım 6, 3 resimden 1. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: adım 6, 3 resimden 2. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: adım 6, 3 resimden 3.
    • Remove all four Phillips #00 screws that hold the hard drive in place.
  7. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: adım 7, 3 resimden 1. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: adım 7, 3 resimden 2. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: adım 7, 3 resimden 3.
    • Lift up on the outer part of the hard drive.
    • Pull the hard drive out.
  8. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: adım 8, 2 resimden 1. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: adım 8, 2 resimden 2.
    • Remove the four Phillips #00 screws holding the HDD in the HDD cover.
    • The HDD should slide out after all screws are removed.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 23
Son 30 gün: 75
Her zaman: 4,224
