Ana içeriğe geç
HP ProBook 440 G1 Keyboard Replacement
Neye ihtiyacın var
  1. HP ProBook 440 G1 Keyboard Replacement, Battery: adım 1, 2 resimden 1. HP ProBook 440 G1 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure the laptop is turned off before you start.
    • Push and hold the release tab on the right and left toward the center.
    FixBot'a Sor
    Yorum Ekle
  2. HP ProBook 440 G1 Keyboard Replacement: adım 2, 2 resimden 1. HP ProBook 440 G1 Keyboard Replacement: adım 2, 2 resimden 2.
    • Pull the battery out.
    FixBot'a Sor
    Yorum Ekle
  3. HP ProBook 440 G1 Keyboard Replacement, Backplate: adım 3, 3 resimden 1. HP ProBook 440 G1 Keyboard Replacement, Backplate: adım 3, 3 resimden 2. HP ProBook 440 G1 Keyboard Replacement, Backplate: adım 3, 3 resimden 3.
    • Push and hold the release tabs on the right and left toward the center again.
    FixBot'a Sor
    Yorum Ekle
  4. HP ProBook 440 G1 Keyboard Replacement: adım 4, 1 resimden 1.
    • Slide the backplate off.
    FixBot'a Sor
    Yorum Ekle
  5. HP ProBook 440 G1 Keyboard Replacement, Keyboard: adım 5, 2 resimden 1. HP ProBook 440 G1 Keyboard Replacement, Keyboard: adım 5, 2 resimden 2.
    • Locate the two screws on the back of the laptop, holding the keyboard.
    • Remove the two screws using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  6. HP ProBook 440 G1 Keyboard Replacement: adım 6, 1 resimden 1.
    • Flip the computer over so as to see the keyboard.
    FixBot'a Sor
    Yorum Ekle
  7. HP ProBook 440 G1 Keyboard Replacement: adım 7, 2 resimden 1. HP ProBook 440 G1 Keyboard Replacement: adım 7, 2 resimden 2.
    • Place both hands on the keyboard and slide it back.
    • The keyboard will only slide back a small amount.
    FixBot'a Sor
    Yorum Ekle
  8. HP ProBook 440 G1 Keyboard Replacement: adım 8, 2 resimden 1. HP ProBook 440 G1 Keyboard Replacement: adım 8, 2 resimden 2.
    • Using a plastic opening tool, pull the keyboard up.
    FixBot'a Sor
    Yorum Ekle
  9. HP ProBook 440 G1 Keyboard Replacement: adım 9, 3 resimden 1. HP ProBook 440 G1 Keyboard Replacement: adım 9, 3 resimden 2. HP ProBook 440 G1 Keyboard Replacement: adım 9, 3 resimden 3.
    • Locate the connector strip between the keyboard and the laptop.
    • Pull the strip away from the connector until it unplugs.
    • It may take some force to make the strip disconnect.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
thanks for that
sir i want original keyboard 440 G1
if u dont mine suggest me
karun kumar - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 8
Son 30 gün: 57
Her zaman: 2,831
