Ana içeriğe geç
HP ProBook 440 G1 Wifi Card Replacement
Neye ihtiyacın var
  1. HP ProBook 440 G1 Wifi Card Replacement, Battery: adım 1, 2 resimden 1. HP ProBook 440 G1 Wifi Card Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure the laptop is turned off before you start.
    • Push and hold the release tab on the right and left toward the center.
  2. HP ProBook 440 G1 Wifi Card Replacement: adım 2, 2 resimden 1. HP ProBook 440 G1 Wifi Card Replacement: adım 2, 2 resimden 2.
    • Pull the battery out.
  3. HP ProBook 440 G1 Wifi Card Replacement, Backplate: adım 3, 3 resimden 1. HP ProBook 440 G1 Wifi Card Replacement, Backplate: adım 3, 3 resimden 2. HP ProBook 440 G1 Wifi Card Replacement, Backplate: adım 3, 3 resimden 3.
    • Push and hold the release tabs on the right and left toward the center again.
  4. HP ProBook 440 G1 Wifi Card Replacement: adım 4, 1 resimden 1.
    • Slide the backplate off.
  5. HP ProBook 440 G1 Wifi Card Replacement, Wifi Card: adım 5, 2 resimden 1. HP ProBook 440 G1 Wifi Card Replacement, Wifi Card: adım 5, 2 resimden 2.
    • Locate the Wifi card, found opposite the battery and across from the hard drive.
  6. HP ProBook 440 G1 Wifi Card Replacement: adım 6, 2 resimden 1. HP ProBook 440 G1 Wifi Card Replacement: adım 6, 2 resimden 2.
    • Remove the wire located near the screws on the wifi card.
  7. HP ProBook 440 G1 Wifi Card Replacement: adım 7, 2 resimden 1. HP ProBook 440 G1 Wifi Card Replacement: adım 7, 2 resimden 2.
    • Remove the two Phillips #00 screws holding the wifi card in place.
  8. HP ProBook 440 G1 Wifi Card Replacement: adım 8, 1 resimden 1.
    • Remove the wifi card.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 1,532
