Ana içeriğe geç
HP ProBook 450 G3 RAM Replacement
Neye ihtiyacın var
  1. HP ProBook 450 G3 RAM Replacement, RAM: adım 1, 3 resimden 1. HP ProBook 450 G3 RAM Replacement, RAM: adım 1, 3 resimden 2. HP ProBook 450 G3 RAM Replacement, RAM: adım 1, 3 resimden 3.
    • The screw is not supposed to come out. It is there to hold the case down.
    • Unscrew the 2.5 mm screw with PH00 screwdriver.
    • Pull the cover off the computer using two hands.
  2. HP ProBook 450 G3 RAM Replacement: adım 2, 3 resimden 1. HP ProBook 450 G3 RAM Replacement: adım 2, 3 resimden 2. HP ProBook 450 G3 RAM Replacement: adım 2, 3 resimden 3.
    • Push the bars that hold the RAM in place down. The RAM should pop up.
    • Carefully remove the RAM by pulling it out.
Sonuç
Jingyuan Zhang
637 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G3, Julie Fall 2017 UMass Dartmouth, Team S2-G3, Julie Fall 2017 üyesi
UMASSD-JULIE-F17S2G3
3 Üyeler
Bir Yorum
What kind of RAM is it?
Luigi Provencher - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 4,029
