Ana içeriğe geç
HP ProBook 450 G4 Disk Drive Replacement
Neye ihtiyacın var
  1. HP ProBook 450 G4 Disk Drive Replacement, Disk Drive: adım 1, 2 resimden 1. HP ProBook 450 G4 Disk Drive Replacement, Disk Drive: adım 1, 2 resimden 2.
    • Power your laptop off.
    • Flip the laptop over.
    • Orient the laptop so the two vents on the bottom face upward and are further away from you.
  2. HP ProBook 450 G4 Disk Drive Replacement: adım 2, 3 resimden 1. HP ProBook 450 G4 Disk Drive Replacement: adım 2, 3 resimden 2. HP ProBook 450 G4 Disk Drive Replacement: adım 2, 3 resimden 3.
    • Use the Phillips #0 screwdriver to remove the 6.8 mm screw that secures the vent panel to the laptop.
    • Use the spudger to separate the vent panel from the laptop.
    • Slide the vent panel off the backside of the laptop.
  3. HP ProBook 450 G4 Disk Drive Replacement: adım 3, 2 resimden 1. HP ProBook 450 G4 Disk Drive Replacement: adım 3, 2 resimden 2.
    • Use the Phillips #0 screwdriver to remove the black 3.2mm screw that secures the disk drive to the left side of the laptop.
  4. HP ProBook 450 G4 Disk Drive Replacement: adım 4, 2 resimden 1. HP ProBook 450 G4 Disk Drive Replacement: adım 4, 2 resimden 2.
    • Use the spudger to push the disk drive out of the laptop.
Sonuç
Sebastian Dow
1.007 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G3, White Winter 2020 Cal Poly, Team S1-G3, White Winter 2020 üyesi
CPSU-WHITE-W20S1G3
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 482
