Ana içeriğe geç
HP ProBook 450 G4 Keyboard Replacement
Neye ihtiyacın var
  1. HP ProBook 450 G4 Keyboard Replacement, Hard Drive: adım 1, 2 resimden 1. HP ProBook 450 G4 Keyboard Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Power your laptop off.
    • Flip the laptop over.
    • Orient the laptop so the two vents on the bottom face upward and are further away from you.
    FixBot'a Sor
    Yorum Ekle
  2. HP ProBook 450 G4 Keyboard Replacement: adım 2, 3 resimden 1. HP ProBook 450 G4 Keyboard Replacement: adım 2, 3 resimden 2. HP ProBook 450 G4 Keyboard Replacement: adım 2, 3 resimden 3.
    • Use the Phillips #0 screwdriver to remove the 6.8 mm screw that secures the vent panel to the laptop.
    • Use the spudger to separate the vent panel from the laptop.
    • Slide the vent panel off the backside of the laptop.
    FixBot'a Sor
    Yorum Ekle
  3. HP ProBook 450 G4 Keyboard Replacement: adım 3, 2 resimden 1. HP ProBook 450 G4 Keyboard Replacement: adım 3, 2 resimden 2.
    • Use the Phillips #0 screwdriver to remove the black 3.2mm screw that secures the hard drive to the left side of the laptop.
    FixBot'a Sor
    Yorum Ekle
  4. HP ProBook 450 G4 Keyboard Replacement: adım 4, 2 resimden 1. HP ProBook 450 G4 Keyboard Replacement: adım 4, 2 resimden 2.
    • Use the spudger to lift the left side of the hard drive up.
    • Pull the hard drive diagonally to the left to release the hard drive from the laptop.
    FixBot'a Sor
    Yorum Ekle
  5. HP ProBook 450 G4 Keyboard Replacement, Keyboard: adım 5, 3 resimden 1. HP ProBook 450 G4 Keyboard Replacement, Keyboard: adım 5, 3 resimden 2. HP ProBook 450 G4 Keyboard Replacement, Keyboard: adım 5, 3 resimden 3.
    • Remove the 6.6mm T8 Torx screw located below where the hard drive used to be.
    • Remove the 6.6mm T8 Torx screw located below and to the left of the circular, silver and black fan.
    FixBot'a Sor
    Yorum Ekle
  6. HP ProBook 450 G4 Keyboard Replacement: adım 6, 3 resimden 1. HP ProBook 450 G4 Keyboard Replacement: adım 6, 3 resimden 2. HP ProBook 450 G4 Keyboard Replacement: adım 6, 3 resimden 3.
    • Use the spudger to press down on the two black tabs that are underneath where the hard drive used to be.
    • Apply pressure to the black tabs until they release and pop out.
    FixBot'a Sor
    Yorum Ekle
  7. HP ProBook 450 G4 Keyboard Replacement: adım 7, 3 resimden 1. HP ProBook 450 G4 Keyboard Replacement: adım 7, 3 resimden 2. HP ProBook 450 G4 Keyboard Replacement: adım 7, 3 resimden 3.
    • Orient the laptop so the keyboard is facing upwards and towards you.
    • Insert the spudger in between the edge of the keyboard and the computer frame.
    • Slide the spudger around the edge of the keyboard until the keyboard is loose.
    • Gently pull the keyboard away from the body of the laptop.
    • Do not pull the keyboard all the way off because there is still a connector cable underneath that needs to be disconnected.
    FixBot'a Sor
    Yorum Ekle
  8. HP ProBook 450 G4 Keyboard Replacement: adım 8, 2 resimden 1. HP ProBook 450 G4 Keyboard Replacement: adım 8, 2 resimden 2.
    • Use a spudger to gently lift up the black locking bar on the keyboard connector.
    • Slide the keyboard ribbon out of the connector.
    • Remove the keyboard.
    • To re-attach the keyboard ribbon, slide it into the connector and swing the locking bar down.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Sebastian Dow
1.127 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G3, White Winter 2020 Cal Poly, Team S1-G3, White Winter 2020 üyesi
CPSU-WHITE-W20S1G3
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 21
Son 30 gün: 126
Her zaman: 9,883
